Spar urethane or spar varnish?
Charleyhorse
I'm replacing the wood on my transom. I have glued two pieces of plywood together, cut it to the right size, drilled the holes, and applied two coats of spar vanish. Will the varnish protect the wood, or do I need urethane? I had the varnish.
I've heard that both terms are now used interchangeably with no real difference in products. Are you using water or oil based?
