linesider
I've got some questions about the wiring for my boat. When I decided to start the mod I bought a 6 switch and circuit breaker panel. I'll attach a photo. A year or so later I'm now starting to really think of placement of everything and what I need to wire everything correctly. The packaging shows the total circuit capacity is 35 amps and 7 individually. I'm trying to read more about it and I understand quite a bit of it but still have questions.
Question 1: I've got a rule bildge pump that shows it is rated for 2.5 amps. With the correct wire size in proportion of length of wire used can I safely connect the pump to a 7 amp circuit breaker. I think the lenght of wire used will be about 7'.
Question 2: How about the nav light and anchor light. I want them on separate circuits and since they pull less than 1 amp is the 7 amp too much as well.
Question 3: Really the same question as 1 and 2 but for the depth finder. I know this doesn't use much power either.
Question 4: Should I or will I need to go with fuses instead because I can't find a circuit panel with anything like 3 to 5 individual circuit breakers.
I'm thinking that I bought the wrong panel for my needs. Can anyone give me some advice and opinions.
Thanks!
Thanks!
