I have a 2004 Minn Kota Power Drive motor on my boat. It came on the boat I bought a few years ago. Ever since I got it, it acted up from time to time which I originally thought was the plug, because I would wiggle the plug and it would work again. So in my infinite wisdom I cut the big, molded plug off the foot pedal and the motor, in an effort to splice them together. But when they were cut off I was able to continuity test them and the plug was working flawlessly. At this point I finally decided to do some research online and quickly discovered this is a common problem and means the control board needed to be replaced. Found online at Northland Marine, it's $75. But I also need to replace my foot pedal, or at least the control board and wire/plug, which is $58. A new pedal is $11 more so I would just do that. LONG STORY SHORT, gonna take $150 in parts to make this old trolling motor good again.
Knowing this motor is 12 years old, would you guys bother to drop $150 into it or would you look into a new motor completely? I'm just concerned this is like an old truck... once stuff starts going, it's like going down a rabbit hole and pretty soon I could have a new motor for what I replaced in parts.
The motor is a 50lb thrust and although I am constantly annoyed by how hard it is to deploy, it's the perfect power for my small 14' side console.
