S&MFISH
Jim,I have it. (Sec 3)Start with a 1'' rod with a T-handle at one end and the other end drilled and tapped for 3/4''. (Sec 2)Now take a 3/4'' rod and thread one end,then drill and tap the other end for 1/2".Make a T-handle out of a 3/4'' nut and 1/2'' rod welded together to screw on the threaded end. (Sec 1) Take a 1/2'' rod and thread one end and grind a point on the other end.
I started this thinking backwards,but when I thought about the end in the lake bed it wouldn't work that way so I reversed the sections. Do you follow me.
Use 2 Vise-grips to assemble and disassemble.
