Piano Hing Source
rscottp
Martha's Vineyard Ma
I am looking for a source for offset aluminum piano hinges. I need the offset to be on both leafs. I checked the site listed in the material supply thread and they didn't have what I was looking for. Thanks in advance.
Got a pic of the prospective installation?...there may be an easier alternative than trying to source a piano hinge with the correct offset etc...
Rod
Oriental, NC
Hinges are for the hatches in my side boxes. Lids will be supported on 3 sides, I don't want a lip on the hinge side because I don't want the opening any narrower. The offset hinge will act as support for back of hatch.
How thick is the decking?...are you using typical 1/8" marine carpeting?...
...At first glance, looks like mounting the hinges on the cockpit side (instead of the gunnel side) might solve your problem?
Rod
Oriental, NC
[url=https://www.tinboats.net/forum/viewtopic.php?p=341879#p341879 said:
1957Crestliner12 » 15 Feb 2014, 00:50[/url]"]How thick is the decking?...are you using typical 1/8" marine carpeting?...
Rod
Oriental, NC
1/2" MDO covered in Nautolex vinyl.
